Cable to antenna
G
GB119
I have a question about two of these cables ....the part number on one is:
MJ-B24LPF0005-150+R
The other older cable has the same part number, except the +R is not there... so
MJ-B24LPF0005-150
Question.....the second cable is from a Navnet VX1 1943C .....will the first part number (MJ-B24LPF0005-150+R) work with the VX1?
Do they look alike? Then I would say yes. We don't use those numbers and have no information on them. You can always ohm them out to be safe. My guess is the R is just a revision for when they changed over to lead free solder on production of all boards and cables.
