The DFF1 itself can't be adjusted without an MFD or compatible PC based software. Typically it is adjusting your RANGE selection but depends on the system you are using if you need to put it into manual range first etc. The detailed instructions should be covered in the MFD or PC software program you are using to run the DFF1.
I'm using 2 MFD 15 and have looked at the instructions and software but still have difficulty. if I put the system in manual first there doesn't seem to be a setting for range on the DFF 1 menu. The only range I see is in the control knob.
