B765LH
Nick
Hello,
Which transducer to choose if in TZtouch3 12" if Airmar B765LH is already installed? :sorry
thanks
Nick
I did't find B765LH in the transducer setup menu, so I'm asking which transducer model to choose. Transducer ID is connected.
Nick
b765 low element is the same as a B75L 300w
b765 high element is the same as B75H 600w
I would pick B75L + B75H from the list of transducer settings in a tzt12/16/19f with version 2.01 software or above.
I didn't know that. I thought that the low element of the b765 is also 600W, well....you can always learn something! Thank you very much
Nick
https://www.airmar.com/xref.html
If you go here, and you type in 40-75A in the search box and hit return,
you will see all of the transducers that use the same 40-75A low chirp element.
then, if you start a new search, and type in 130-210D and search,
you will see all of the transducers that use the same 130-210D high chirp element.
