Hello
I'm planning for DFF3D and a new Chirp sounder, most likely tZt3. I'll either do combination pocket mount or two separate transducers depending on my installers advise. I'm trying to decide between the High Wide frequency of the B275lhw vs the Narrower High frequency of the B265lh if I go with DFF3D.
I typically fish
Winter:
-10'-150' for lobsters where pinpointing small rocks, seaweed, and ledges is very important
-200'-600' for bottom fish where pinpointing rocky reef structure is primary, and fish ID a second
Summer:
-50'-150' Surface fishing. Fish are suspended so primary is bait/fish orientation and beam width, Second is Target ID.
-Offshore in thousands of feet of water but most activity is in 50-200' with max relevant depth maybe around 400'. Boat speeds range from 3 to 14 knts. Width of beam and bait/fish orientation are primary. Target separation secondary, and no need for bottom detection.
I'm leaning toward the B265lh because of the narrow cone angle in high for my winter fishing since I plan on DFF3d which already has an even wider beam than High Wide. That said, with the large range of frequencies in High Wide (vs Low), I'm betting the target ID and amount of info transmitted is pretty awesome. If for some reason I couldn't do Dff3d, the B275lhw becomes very attractive.
But assuming I can do DFF3d. How would the 25 deg cone angle of the High Wide compare to the 25 deg cone angle of the low when suface fishing or offshore? Seems like the wider range of frequencies and higher frequencies would mean more detail on the High Wide but would you consider the 25 deg Low chirp much inferior to the 25 deg High Wide in those summer applications?
I typically fish
Winter:
Summer:
