I have a NAVpilot 711c connected to my hydraulic steering on my outboard motors. When trolling at low speed, going into the wind, frequently the wind will push the bow of the boat to one side and the autopilot will try to correct but the pilot will push the steering ram hard up against the end stops and bind it up. It seems that the pilot should stop prior to hitting the stops but it doesn't.
I am set up using Fantum Feedback as I don't have a rudder reference sensor. When I set up the installation I set the end stops in the software slightly before the actual physical ends of travel on the steering rams.
So is this behavior as expected? If so, is there anything I can do to resolve the problem? I am concerned that some part of the steering system may be damaged because the pump puts a large amount of pressure on the system.
Thank you,
Jim
Thank you,
Jim
