I am using a Navpilot 711c connected to a PG700 for heading and also connected to a the N2k (CAN) bus for other nav data, including position.
When I look at any of the displays (e.g., STBY, AUTO, NAV) on the device, the posn data are blank. When I look at the "sensor in use" menu for that mode, POSN shows blank - a dashed line.
However, when I go into the installation menu to look at the CAN bus setup, I am receiving the proper PGNs and when I look at the Sensor selection menu, I do have the correct device selected as the position sensor. A CAN bus test returns OK.
How can I get the posn data source to show up on the sensor in use?
Thank you,
Larry O'Keefe
Nordhavn 5012 Miss Miranda
La Paz, MX
Thank you,
Larry O'Keefe
La Paz, MX
