I'm installing a couple of 7011C autopilot controllers. It would be very helpful to know the range of viewing angles, both horizontal and vertical, that will deliver optimal visibility.
One controller is going on a a vertical panel above eye level, so I will be looking at it from maybe 30 degrees below straight on. The other one will be on a horizontal dash, in direct sun, so I would be viewing it from 45 to 60 degrees below straight on. The same question applies to TZT2 displays. Should I expect problems with these locations?
These specifications are well known to the display designers and the LCD suppliers. Can anyone tell me what they are?
Thanks!
Thanks!
