B
bogie418
One day out fishing the head unit quit 'seeing' the transducer signal. It was reading the bottom like normal then it kinda lost its mind. It cycles thru different depths every couple of seconds like its hunting around for a signal.(something like 2500ft, 600ft, 15ft) If I plug in the 10 pin connector into the back or leave it out, the screen cycling is the same.
The p66 cable was cracked and corroded under the waterline where it enters the transducer. I replaced it. The same thing is happening with the brand new p66.
All the buttons and dials work.
ROM :OK
SDRAM: OK
NEMA:
TEMP: 50.2 F
SPEED: 0.0
POWER 12.6 V
ECHO: 1048576
The echo goes from 1048576 to 3, back and forth
Any ideas?
ROM :OK
SDRAM: OK
NEMA:
TEMP: 50.2 F
SPEED: 0.0
POWER 12.6 V
ECHO: 1048576
Any ideas?
