islandtime,
The transducer that you have selected, the 526TID-HDD is one of my most recommended transducers to use. However, judging by the single picture that you have provided for this transducer's installation, (I would have liked to have some pictures of the sounder as speed, and pictures also showing outside of the hull where the transducer is mounted, and what might be around that transducer). Is there a keel, or any hull chimes, or water intakes. Are there other transducers present also adding to the turbulence problems..? :angry
Where this transducer is currently located, its my opinion that it's too far back on the hull causing severe turbulence, especially being too close to the propellers. :noway
I typically locate transducers at least 1/3 aft of the hull, centerline as possible, and away from any propeller(s) and/or shaft(s). Usually just forward of the engines are typically good locations.
With transducers, you need to have water flowing under the hull must be smooth as possible with a minimum of bubbles and turbulence (especially during high speeds), and I don't think that's happening here.
If it were me, I'd relocate the transducer a little more forward if possible. I know that with trailer boats can be difficult for transducer locations. But where you have that transducer now, its clearly not working.
-Deep Blue
