I ima Guest Jun 1, 2020 #1 FCV295 with 50-200 1T. Problem with high F weak echoes and doesnt display depth . LF working fine Any ideas
S Snips Guest Jun 3, 2020 #2 Both channels on the FCV-295 are the same. You can actually program both for 200Khz if you want. If the HF doesn't work into either, then I would suspect the transducer. Snips
