330B
marchyfuruno
Finally going to update my rolled over 330B GPS antenna. The current 330B antenna is 0183 configured. Can I use the same installed cable with a newly purchased 0183 330B antenna?
Yes, if you get a newer GP330B, you can use the existing cable from the older version GP330B.
Thanks for the quick response Johnny. Does it make sense for me to install an N2K GP330B with N2K cable instead of a GP330B 0183? Will my NAVNET 3D be able to recognize the N2K. I'm not sure if I have to install a 0183 to N2K converter.
NN3D can read the GPS via 2000 or via 0183. I normally recommend NMEA 2000 if you have an established bus. I wouldn't go 0183 and buy a converter.
