1870 F need help
hi i have a 1870 f when i first used my unit my plotter left a track of where i have been now there is no track tried reading the book but every thing i try don't work please any info would be grate
You should ensure that tracking is turned on.
1. Open the [PLOTTER] menu then select [TRACK] and [RECORD TRACK].
2. Select [On] then press the ENT key.
3. Press the ESC/MENU key to close the menu.
You can also stop or start recording the track from the RotoKey menu. Select [Track]
then push the RotoKeyto start or stop recording.
If the tracking is On but you still don't see it, you might have selected the HIDE feature. To show the track again
1. Open the [PLOTTER] menu then select [TRACK] and [SHOW TRACK BY COLOR].
2. Select the color to display then press the ENT key then turn it On.
3. Select [On] in [All] to display all colors.
4. Press the ESC/MENU key to close the menu.
More details on tracking can be found in the user manual in chapter 2.
