1815 with IF-NMEA2K2
  • Thread starter Thread starter GB119
G
GB119
Hello.. looking at the wiring schematic for this radar, it looks like it will receive heading on nmea port 1.... will it accept both heading and position on nmea port 1 if using the adapter in the topic subject of this post... and will it be good for TT?
Next question.. will this radar put out the TTM string for use with a plotter assuming it is connected as above? That is port 1 is transmit/receive with IF-NMEA2K2 wired correctly to port 1. Plotter is in nmea2000 network and can recover the converted pgn (TTM)
Thanks..
You shouldn't have a problem receiving both, the heading and Pos all on port 1. And the IFNEMA2K2 will pass it.
But I think with respect to TTM you are out of luck. I have not found a N183 to N2K gateway converting TTM to PGN128520.
The IF-NEMA2K2 claims to do it in the other direction and I wonder what for, as my TZT2 and NXT radar are not sending out PGN128520, but do send TTM on N0183.
