Boost240sx
I have a 1742c that the display has gone bad and I'm trying to figure out my options on if it is finally time to upgrade to new technology or can I still use my existing array.
A. My open array has a RSB0047-051 base with the 2 ft array with the large rectangular plug on the cable. Can I switch the cable out to the round plug to be able to run at least a slightly newer display or does my current array only wire up with the rectangle plug?
B. What other diplays would be able accept the large rectangular plug?
Thanks.
Thanks.
