Tpalmerjr3
Currently have a TZT3 12" withh DFF3D utilizing the 165T-50/200-TM260 transducer and a separate B60 to the internal sounder. B60 is installed forward of the step (Caymas 28HB) and good for running at speed. Would like to be able to run the 50/200 from the transom mount, manually switching from the B60, for deeper water. The TM transducer uses a 10 pin connection. Some places in the installation documentation say that it will require the MB1100 others say that a 10 pin to 12 pin adapter (Furuno 000-197-069-10) will work if it's a diplexted transducer but I can't find that info for the transducer. Has anyone tried to hook up without the MB1100 successfully? Would much rather avoid the extra hardware if it's an option.
