I finally got to splash my boat today after getting the transducer installed last week. I have a DFF3 and a R599LH transducer with a ST-02MSB speed and temperature sensor. When I first turn the system on the machine will go back and forth on the depth reading between the TZT12F and the DFF3 on the sensor list even though the DFF3 is set as the preferred. Problem is I don't have a transducer hooked to the TZT2 unit. It even showed the PG700 as the current source for depth at one point when the DFF3 was set as current.
Another question I have and I could possibly be blind. My temperature sensor is plugged into the Dff3. I'm getting the temp reading but for the life of me I cant figure out how to get the Sea Surface Temperature (water temp) displayed on the sounder screen. When I go to the sensor list it shows the DFF3 as the source and shows the temperature there. I just cant figure out how to get it on the screen.
Also my autopilot is in my NMEA2k system along with everything else. On my autopilot display it will not show my position and also wont pick up the speed on auto mode. I'm just wondering if theres something simple I'm missing. Here is a picture to hopefully help diagnose the problem.
These are just minor issues and I love these units. They are lightyears above my previous units. Thank you Furuno!
