TZtouch up dates, and gps loss of signal.
will the 5.02 update for the TZtouch2 work on the TZtouch.
And I was out the other day and lost gps signal (Postion lost). Usually it comes back in 10 seconds or so but not this time after 20 minutes of no signal I shut the tz off and turned it back on again and the gps worked for 2 minutes then lost signal again for the rest of the 3 hours I was out fishing. Thanks for any help.
TZT and TZT2 are two completely different operating systems. You can NOT use the software from one series into the other. It wasn't clear; Do you own a TZT or a TZT2?
Unlike the TZT2, the TZT does not have an internal GPS sensor. What does it show selected as a GPS source for position under your SENSOR LIST? Do you have any photos on where your GPS antenna has been installed on the boat?
