Dff-1 connection to SS264W
tunafishhkg
Hi,
Got a furuno 10Pin SS264W that the manual says it includes built in diplexer so is a MB1100 still needed for 1KW use of this transducer to connect it to a DFF-1 module witch means I need to cut off 10pin plug on the SS264 to connect it to a MB1100 then the DFF-1?
Tunafishingkg,
The SS264W will connect directly to the DFF1. The 264's are a single frequency transducer and normally used in pairs. There is a short pigtail coming out the transducer that is used to connect to it mate.
TunafishKkg,
You need the MB-1100 when using non-diplexed transducers like a CA50/200-12M.
