Dff3d ip address
Aggeloseco
Hello, I installed a DFF3D on my Boat yesterday, what ip should I assign to it in order to be connected to my PC? I am using maxsea pro v3.3
Ok i managed to installed it properly, now it has to be tested.
more pics
Aggeloseco,
I would start by learning the DFF3D in it's simplest form, as a single (10 degree) beam sounder. Here you can see how the Gain, TVG and Clutter settings all interact. Then widen the single beam out and see if you need to readjust any of the settings. Once you have done that you can progress to the triple beam mode, then the sector and 3D modes.
Ok snips I will do so.. I have one very first question as I tested it yesterday for the first time.
Can i zoom on the single beam? I wasn't able to zoom or to shift to the last meters of the bottom.
Aggeloseco,
Under the display icon you will find a zoom control.
Ok thank you very much, sorry but these are my first days out with the new system , so I try to set everything up
I do have another bigger problem. The water column ( 3D History) functions only in find fish mode and actually doesnt even show fish I tryed everything friom menu without success.
Appgeloseco,
Did it show fish in the single beam mode? Your first screen shot didn't show any. Also know that the single/triple beam, section and 3D have separate settings.
No it didn't. I actually see fish only in the cross section . I know about settings but I cannot find anywhere a setting that would allow me to see the 3D water column with depth shading instead only fish mode.
Also another thing, when I zoom in the single or triple beam, it doesn't zoom to the bottom, the bottom is being shifted downwards and disappear, and the first meters are zoomed,I think a shift function is missing.
Another example of the 3D History / water column
Aggeloseco,
I hate to sound like a broken record but you need to be able to see fish targets in the single/triple beam mode first. If you can't see fish targets here we got to determine why not i.e. is the power set at 10 or using the gain in an Auto mode. Another item to check is if you use Manual gain can you flood the screen with noise? If you are not able to see fish in the single/triple beam mode you won't see them in the others either.
Hello, so I did like it was said but unfortunately I didn't had any success
Good morning Aggeloseco,
Thank you for providing the photos in your last post. I noticed something in one of the photos. Please see below, I circled it in Red. The fish targets in the 3D history view can be colored based on Depth or Target Strength. However, the "Target Strength" option is only available for the WASSP Generation 3 Multibeam and not for the DFF3D. With the DFF3D attached you will want to make sure the fish targets are colored by Depth.
This can be found in the TZ Pro user guide. Please see reference below.
Kind Regards,
  • Water_C.pdf
Aggeloseco,
I believe Snips is correct. I also believe it is just a setting. Once the change is made you should start to see a more realistic 3D History presentation that looks something like this. These screen captures were taken on my boat recently. As you can see from the attached pictures, my bottom colors are green/blue/yellow where yours are all grey and my fish are gold where you are showing no fish at all. Please let us know what you find out after your next test. I am sure we can figure out what needs to be changed to make this work for you.
Unfortunately I can’t shade the Bottom because I use maxsea pro software , and there isn’t the ability to shade the bottom with color, only to see fish school
