Had the DFF3D on the water for the first time yesterday. Everything seemed to work fine. It's clear that there is a learning curve, especially since I'm learning the TZT along with the DFF3D.
I have the TM54 transducer and using the multi-sounder display as a reference I was able to get up to about 20 kts. before any noise started to appear on the display. I'm assuming that this is pretty good but would like confirmation.
The Navpilot 711C was also tested on the water for the first time yesterday and although I was not able to test it with the DFF3D, I would like some help with how to use the DFF3D history to place a mark that I can navigate to using the Navpilot. The user manual is not
very clear in this regard.
I was running the DFF1 along with the DFF3D since I'm very familiar with the DFF1 and wanted to compare things. For the most part the DFF1 and DFF3D multi-sounder display center beam were nearly identical. With the cross section display I needed to adjust the gain(? ) from 30 up to about 60 to get things to display in the water column.
With the 3D display, how do I shut off or speed up the video playback (roll up) that it does each time you select this display? When I select the 3D display I want to see whats under the transducer immediately. I'd like to keep the history too, but don't like the delay for the roll up show.
Lastly, I would like to know how to save screen shots of the various DFF3D displays.
