Temp not marking correctly - 525ST-MSD transducer
Postby echavez1 » Mon Dec 18, 2017 2:46 pm
I have the 525ST-MSD transducer/f block
It's been working fine overall, but the temp stopped marking properly, it seems to be about 10degrees colder than the water temp is actually at.
Is there a way to fix, adjust or test it either on the water or off?
Thanks,
Cesar
echavez1
Re: Temp not marking correctly - 525ST-MSD transducer
Postby Deep Blue Sea » Tue Dec 19, 2017 9:14 am
echavez1,
It sound like the thermistor which that is internal to the transducer might be going bad, it rarely the cable or sounder.
There is also an option to replace your speed insert with one that contains a replacement temp sensor. You might discuss the various options with your dealer.
Deep Blue - ;)
Fishermen know that the sea is dangerous, and it’s storms terrible, but they have never found these dangers sufficient in reason for remaining ashore." — Vincent Van Gogh
User avatar
Deep Blue Sea
Moderator
Moderator
Postby Johnny Electron » Thu Dec 21, 2017 5:23 pm
You might also check your temp offset setting in the unit for the sounder. It could be that you can just adjust (calibrate) the temp there. The forum also has postings describing how to OHM out your transducer temp sensor to tell if it is bad or not.
User avatar
Moderator
Moderator
Return to Fish Finders & Sonars
Who is online
Users browsing this forum: Bing [Bot] and 2 guests
