TM265LH transducer with DFF1-UHD
Postby flowmotion » Tue Dec 12, 2017 9:15 am
The DFF1-UHD gives bottom discrimination with 265LH thru-hull transducers. The recommended transom mount transducer (TM275LHW) does not enable bottom discrimination.
Is it possible to use the TM265LH with the DFF1-UHD to enable bottom discrimination with a transom mount transducer? If so, are there any tradeoffs?
flowmotion
Re: TM265LH transducer with DFF1-UHD
Postby flowmotion » Tue Dec 12, 2017 2:10 pm
the reply
"Unfortunately, the Chirp transom mount transducer that we have currently available (TM265LH and TM275LHW) are both not compatible to do the bottom discrimination. The only Chirp transducer that can do bottom discrimination are B265LH and PM265LH. So far there hasn't been any words for future changes in software that will make them enable that function.
Thank you for contacting Furuno USA, Inc.
Kenny
Light Marine Tech Support
Furuno USA, Inc."
flowmotion
Return to Fish Finders & Sonars
Who is online
Users browsing this forum: Bing [Bot] and 2 guests
