Furuno waasp system
Re: Furuno waasp system
Postby Snips » Wed Dec 06, 2017 8:52 pm
Levi,
If you are using an SC-30 you are also using the IFNMEA-SC interface. This interface has two output ports so I am assuming you used one for the WASSP and the other for the 711C. First thing is to make sure you didn't reprogram the port that is feeding the pilot. If you want you can switch ports on the SC interface and you can use WASSP's serial transfer task to view the data.
Moderator
Moderator
Postby Levi Curtis » Thu Dec 07, 2017 3:41 am
Thanks Snips, will keep you posted
Levi Curtis
Previous
Return to Fish Finders & Sonars
Who is online
Users browsing this forum: Bing [Bot] and 2 guests
