FCV-295 in a small boat
pepegrisu
Hi,
I have one White Shark 225 (7 mts) with one FCV 588 and a B260 thru hull transducer. Now I need lo have something to see fishes deeper, between 820 to 1300 feet. I want to install a FCV 295 but I´m not sure about the transducer. I can´t install a big thru hull one because the boat is too small and I don´t have idea about the installation in hull. The boat is fiberglass and max. speed is about 30 knots.
Also I usually fish in 90-200 feet.
Can anyone help me please?
Pepegrisu,
So how does your current setup work at 1300ft? You are very limited on what you can fit due to hull size.
Pepegrisu,
Personally I don't recommend using any in-hull transducers due to their performance loss. If you think you want to go that way I would recommend finding a boat that is using that exact set up to see how it works.
