Best 600w transducer for tzt2
blue yonder
Hi Guys,
Recently I burnt out my transducer and am looking for a new, better one! What is the best one I can get that will use all the features I can use with my TZT2? Im looking at 600w versions as I don't really fish that deep. Id like it to have reboots, chirp and Acufish.
Ultimately Id also like one with a paddle wheel incorporated into it as well.
Cheers!
Nic
Blue Yonder,
Just know that basically all 600 watt transducers use the same internal elements. This means that the performance will be very similar between them. If you want to have a paddle wheel you actually have only a couple of choices. Transom or thru-hull, of these two I would lean towards the thru-hull with the fairing block. I would look at the 525STID-MSD.
Hi Snips,
Thanks for this. That is actually the transducer I had except that it didn't seem to be that great and did not show acufish and didn't seem to have chirp capability... Should it have?
Blue Yonder,
The TZT2 is not a Chirp sounder and the 525STID-MSD is not a Chirp transducer. However the ACCU-FISH feature should have worked.
