GP-1870F data integration with RDP-142 (Radar 1715)
Postby nawar76 » Sun Feb 04, 2018 11:59 pm
How to integrate those two devices so that both will display the needed data info. As for now RDP-142 is attached with Radome Scanner/sensor only, while GP-1870F is attached with GPS antenna, sounder and heading sensor.
nawar76
Re: GP-1870F data integration with RDP-142 (Radar 1715)
Postby Johnny Electron » Mon Feb 05, 2018 8:06 am
The 1715 uses NMEA 0183 and the GP1870F uses NMEA 2000. You will need to build a small NMEA 2000 bus and use a converter like the Furuno IF-NMEA2k2 to convert the 2000 data to 0183 so you can wire that to the 1715. You might look at some of the example interface drawings listed under the GP1870F on our product page.
User avatar
Moderator
Moderator
Return to GPS Chart Plotters
Who is online
