GP-32 Wiring help please!
So I have this old GP-32 that I just want to extract the data from to my PC.
It has a 7 wire connector plugged in with colors - brown, red, orange, yellow, green, blue, purple.
I also have a data cable with colors - red, black, blue, yellow, white, green, and an exposed silver wire.
I need to either connect the two together because the plug that connects these two wires is broken. Either that or directly connect the plug from the GP-32 to some sort of serial or usb connector.
Can anyone steer me in the right direction?
amill411,
Here is the wiring diagram that you can use if you are using the GP32's Power/Data Cable
Hope this helps.
- Deep Blue :)
