RDP-148 interface with GP-7000F
I have an RDP-148 I use for my radar. I also have a GP-7000F I use for a GPS/Sonar. Can I interface them and be able to see the GPS/Sonar data from the 7000 on the RDP-148? If so what connection do I make for the interface. Thanks!!
You can never see the sonar picture from the GP7000F on the RDP-148 or see the radar picture from the RDP-148 on the GP7000F. You can feed NMEA data between the two units. For example the Depth/temp numbers can be shared from the GP7000F to the RDP-148 with wiring the two up together via NMEA 0183. This way you should see DEPTH or TEMP in a data box.
Johnny,
Thanks that helps. If I hook the two together by the NMEA. Do I still need the GPS antenna on the 148 or can the 148 use the data from the 7000F for position?
Thanks!
