GP33 connection to 12v panel
RBilly
I recently purchased a new GP33 GPS. I will be using it as a stand alone system on my
O'Day 28 sailboat. Do I cut the plug off one end of the M-12 cable to expose the red/black power wires to connect to 12v panel? Or is there a connector( with red/black wires exposed and plug in on other end)?
Rbilly,
Yes you may be able to partially cut the m-12 cable exposing the black and red wires.
Once that happens you can connect it into the vessels 12V supply panel.
No there is no connector on the power side.
Regards,
Mr. Radar
