Antenna rsb0071 for 1835
Postby Ragnar78 » Wed Dec 06, 2017 6:11 am
Hi to all members Furuno uses and sorry for my englisch but I'm Italian and with foreign languages :sorry .I've never been able to do.....I wanted to ask you a question as my dealer Furuno not my answer on my boat and there is a radar antenna Furuno RSB-0071-ADB9ZWRTR057 I wanted a clear to change the cable I can use this antenna with a screen of 1835 hope to save some money thanks again for accepting me in the fantastic forum Furuno.. :jump :jump :jump
Ragnar78
Re: Antenna rsb0071 for 1835
Postby Deep Blue Sea » Wed Dec 06, 2017 1:46 pm
Ragnar78,
Thanks again for your question, and just to clarify. Are you asking what Radar Antenna with work with a 1835 (RDP152) Display..?
The RSB0071-057A is the only correct Radome that will work with a 1835 Display. And here are the following part numbers for available Signal Cables:
001-409-510-00 10M SIGNAL CABLE/ASSY
001-409-520-00 15M SIGNAL CABLE/ASSY
001-409-530-00 20M SIGNAL CABLE/ASSY
Hope this helps,
Deep Blue - :)
Fishermen know that the sea is dangerous, and it’s storms terrible, but they have never found these dangers sufficient in reason for remaining ashore." — Vincent Van Gogh
User avatar
Deep Blue Sea
Moderator
Moderator
Postby Ragnar78 » Wed Dec 06, 2017 11:54 pm
Thanks for the answer but I'm worried because the antenna has a bit of years the plug is not the same and laks the final A of the ID number TYPE RSB-0071 SER.NO.R128-2087 FCC ID:ADB9ZWRTR057 explain my adoubt and that in 057 the A is missing the connection the cable are the same thanks
Ragnar78
Postby Ragnar78 » Thu Dec 07, 2017 12:00 am
Ie missing A after 057 I would not want the antenna are different
Ragnar78
Return to Radar
Who is online
cron
