Azimuth abnd heading line alarm DRS4DNXT radar
Postby Bear13 » Sat Nov 25, 2017 7:46 am
My radar is networked with TZtouch2 displays. Just installed a couple months ago. Yesterday while idling down the river the radar quit working. On attempt to restart I get an azimuth and heading line alarm, I had rebooted several times no avail. Fuze is good so there's power. The alarm code is azimuth alarm - RD003213, then the headline line alarms pops up. All other equipment operates fine. AIS, Sounder, GPS, Weather... Please help. First time ever I had issue with a Furuno piece of equipment. Radar does not spin up and I do not hear the antenna rotate.
Bear13
Re: Azimuth abnd heading line alarm DRS4DNXT radar
Postby Johnny Electron » Tue Nov 28, 2017 6:27 am
It sounds like your antenna might not be turning or something has gone wrong with the scanner unit. You might open the dome cover (when it isn't raining) and from a distance transmit and see if the array is turning or not. If not turning, you should contact your local dealer for service or send the unit in for evaluation.
Johnny Electron
User avatar
Johnny Electron
Return to Radar
Users browsing this forum: Bing [Bot] and 1 guest
