How well does the DRS4D-NXT track rain?
cp10415
I am in the process of determining which radar to go with for my 30' fishing boat. I read some of the recent posts in this forum about the NXT and its target tracking and bird mode potential. But I would like to know how it does with regards to tracking rain. So, with Doppler, I suppose I can see rain coming or going easier?
It sees rain as well as any X-band radar but better because it will colorize the rain and show you moving targets beneath the rain without the need to turn on a rain filter. It is the first radar that I know of that can see both heavy rain and targets in an area at the same time.
cp10415,
Attached is a picture of the radar image from DRS4D-NXT displaying rain (in blue) while also using the Target Analyzer feature.
Hope this helps.
DB Cooper":37bvjqne said:
cp10415,
Hope this helps.
Great! Does it show storm cells direction of movement?
My understanding is that I can use TimeZero Pro software on a PC with the DRS4D-NXT (in place of a Navnet Display).
Anyone know whether TimeZero Pro will show the rain echoes?
Einstein-
You might want to contact Nobeltec for how they display rain on TZ Pro. I am sure it will work as well as on a TZT unit, but they may have some actual pictures.
Nobeltec confirms that the rain mode option is available on TZ Pro.
I'm wondering if the DRS4D-NXT actually sees up (azimuth) i.e do you know whether it can detect clouds?
Einstein,
With a vertical beam width of 25 degrees, and output power of 25 watts. The DRS4D-NXT can detect Rain. It cannot however, detect rain clouds. :noway
- Deep Blue
