Is the 1712 radome compatible with any other Furuno models?
I just sold my display unit to someone, as I haven't had a radar on my boat for several years. Just no fog where I live.
Is this radome compatible with any other Furuno radars? The radome is the RSB-0087-068.
I see some circumstantial evidence that it may be compatible with certain units at this link:
http://www.furunousa.com/ProductDocumen ... akdown.pdf
PJ,
The 1712 RSB0087-068 2.2KW Dome/Assy is a Liner Processing - 12V Tuning Unit. The RSB0087-068 Dome/Assy is only compatible with another 1712 Display, and it cannot be used for any other radar system. :noway
The drawing you are referring to is where the same 18" Upper/Assys and Lower/Assys (Plastic Housings) were used with other systems, However you will note that different RTRs were used, and well as different Processors and Cable/Assys within all of these systems.
Deep Blue - ;)
That's what I needed to know. Thanks for the quick reply.
