Hello. I have an issue with my now 4 year old DRD2D. It has worked great until now. Today I had a Tune Error. I read in detail posts on a similar issue with a DRS4D and did a number of tests per the forum notes. Details below.
* Radar turns fine when 'on'
* The switch inside works great. I tested with Ohm Meter.
Here are my readings from the Service Man:
Operating Time: 5093hrs
TX Time: 3221hrs
TX-HV: 343.5v
12V: 12.1V
5V: 5.0V
3.3V:3.3v
Pulse Control Voltage: 7.7Volt
Tuning Voltage: 3.9v, 1.8v, 5.3v, 6.0v, etc. Cycles when in TX mode
Arpa Echo: 0
Arpa Land Echo: 0
I also updated to 2.11 from 2.07 to see if that made any difference. So far nothing. I go into the radar optimization screen, and get an Optimization error. I've zoomed in and out on the radar range to see if it works close in or far away, and at all levels of zoom I get this error.
Any suggestions? I am currently in NZ, getting ready to sail North, but need to get this resolved. Could this be a Magnetron issue? YIKES.
TX Time: 3221hrs
TX-HV: 343.5v
12V: 12.1V
5V: 5.0V
3.3V:3.3v
Arpa Echo: 0
Arpa Land Echo: 0
