RDP-139 scanner to non-Furuno Display
We have a customer that wants to connect his NAVNET RDP-139 open array scanner to a radar display or MFD (not been purchased) but not Furuno. Can this be done? Doesn't seem like a good idea but if it can be done what would be required. If it can't be done or not recommended can you explain. What display would be an upgrade for the RDP-139 to connect to the existing scanner? Thank you.
Rich
It cannot be done. Furuno radars only work with Furuno displays.
What is the model number of the scanner your customer has and we will advise what current models, if any, will work.
Thank you Melville. I'll check on the scanner model. Have a great day.
Rich
