RDP139 RSB0071 radar cabling
Re: RDP139 RSB0071 radar cabling
Postby C-Bass » Thu Oct 12, 2017 5:18 am
Good afternoon William,
Glad things are starting to work out. The part number for a 7-pin to bare end 5m cable is 000-154-028. You should be able to search the internet for one.
Kind Regards,
C-Bass
C-Bass
Moderator
Moderator
Postby CrimsonTide » Fri Oct 13, 2017 6:29 am
Hello C Bass
Tq for the link, will do
Cheers
William
CrimsonTide
Postby CrimsonTide » Wed Oct 18, 2017 5:37 am
Hi C Bass
Decided to use the data port 2 for Nmea 0183 input from the GP320 Gps. Followed the color coding and splicing correctly with your kind info
I had to reconfigure the settings on the 139 display and entered OFF for the Gps port Data 1.
I entered Data port 2 as GP320. All functions worked well on the 139 afterward and switched it off
But the next time I switched the 139 on and every time after, it will show no Gps info. I have to edit the Nmea data port 2, which is showing on, enter off then on again, then it works...
Any reason why?
Rgds
William
CrimsonTide
Postby C-Bass » Wed Oct 18, 2017 11:07 am
Good afternoon Crimson Tide,
Thank you for the follow up. So Data Port 1 is set to "Off" for "Furuno GPS Sensor." On data port 2 you said you can turn the "Furuno GPS Sensor" "On or Off?" When you cycle this setting the unit gets a Lat/Lon? On our test units for we have not been able to turn "Furuno GPS Sensor" "On/Off."
When you hit the Menu Button, choose System Configuration, then choose Nav Options. What is the current setting for "Nav Source?" Is it set to: Furuno BBWGPS, GP, LC, or All?
Try changing the Nav Source: to "Gp" then cycle power to see if it works. If it does not try changing the source to "all."
If none of those work: try Furuno BBWGPS.
It is difficult to say because as i mentioned above we cannot replicate turning on/off Data Port 2 "Furuno GPS Sensor."
Let us know how your test goes.
standing by
C-Bass
C-Bass
Moderator
Moderator
Previous
Return to NavNet vx2 & NavNet 1
Who is online
