NavNet VX2
Added DFF1 and a 1kw B260 transducer.
I am having a temp readout issue as follows:
There are two choices of large or small for the readouts located on the bottom of the sonar screen. The temp readout does not display anything other than ---- although I can see temp readings when going through the setup process....It just will not display when I back out of setup to the main sonar screen.
If you choose the large setting it almost completely blocks the depth readout on the bottom left corner of the screen....
I have a 2 second green blinking light. I did choose temp and time to be displayed on the main sonar screen.
If I choose the small readouts, I think you have six options that you can choose to view. If I choose six, I can only see about 4.
I have DIP switches 1 and 4 down and 2 and 3 up.
I used the blue cable from the dff1 to the network port on the back of the vx2.
Where am I screwing up?
I would like to see the temp and I would like to choose large and it now cover up my depth reading on the lower left hand corner of the screen.
Thanks,
Tom
Thanks,
Tom
