I'm helping a friend update his VX2 chart plotters. They are RDP-149s. The serial number on one is 4345-6005. It is running 4.01.07. I attempted to load the 4.03 software, but it is not recognizing it when it boots with the SD card installed. This is the same SD card that I used to upgrade my own VX2s, so I know that the SD card is the correct format and size.
The reason for the software update is that I added AIS input on DATA2, but it is not recognizing the AIS input. I made sure that the Vesper Marine AIS was sending only pure AIS data and no other data. Do you think that a software update will also correct the AIS issue?
What do you suggest?
Thanks,
Bob
Thanks,
Bob
