Where can I find an operators manual for RMC-100 remote controller. I have two VX 2's and two RMC-100. Neither RMC-100's will connect to either VX2. I assume that instruction how to connect is in the manual.
The RMC-100 Remotes were used for all Navnet VX1 Displays, and the first year when the Navnet VX2 Displays were released only. So if it's an older VX2, the remotes may not work as there are no infrared sensors available in the unit.
However, you can reprogram the VX1 to the remotes by doing this:
Goto MENU,
Goto to System CONFIGURATION,
Goto to GENERAL SET-UP,
Goto to NEXT PAGE,
Select INFRARED REMOTE
Select A-B-C-D
To change to mode on the RMC-100, push the "0" and "2" keys together until the remote communicates with the VX1.
Thanks for your help.
I now realize that my VX2's have no infrared capability which is probably the reason I found the two RMC-100's buried at the bottom of a drawer still in their original packaging. Another mystery solved.
