Is there a setting that needs to be changed? My track line setting on my GPS keeps over writing vs. saving my last trips for reference. Any idea what needs field needs to be changed to prevent this?
Your track memory is full. They can be saved if you wish.
I suggest you set one of your function keys on the plotter screen to start and stop tracking so you are not leaving a trail when you don't need it.
This can be found in the manual which is available on our website.
You can also adjust the distance between your track points to stretch how long/far you tracking lasts before being filled. In the manual you will also find where you can adjust the memory allocation between your tracks and marks (not waypoint). If you don't use marks, you can reallocate all the memory to your tracks giving you more track points.
