Hello, I have a 2003 version of Nav Net 1. It was on a boat I purchased in New Jersey and brought to California. No manuals were provided by previous owner.
The system is a 10.4" and 7" on lower station and another 7" on the tower. It has a 36 mile radar connected to lower station 7" display.
I changed the tranducer to a 1kw hdd unit and used the hole for the old transducer as a paddle wheel sensor. I connected these to the BBFF1 unit with a y conector
1- After reinstalling the tower, the GPS would not get a fix. I changed a few settings trying to get it to work, mistake on my part. I replaced the GPS antenna and got it to work. I noticed that the 2, 7" displays do have speed over ground. Is there a setting issue?
2- I have a Simrad AP 22 and it does not get Position data from the gps. It did before I changed settings.
3- Since the boat came from the East coast, the Waypoints default to East latitude. I can change them, but can the system be changed to West latitude?
4- The unit is a Navionics unit and the chart detail is horrible. I found a used 1999 chart card for California and it is the style that is no longer in production. Does Furuno still produce and sell the vx2 product line? I did not want to upgrade this system, but I may have to. My lower helm doe not have the space to use the new larger displays. I have room for the current 10.4" and 7" displays.
Is there a list of settings that I can use to restore the functions I need?
The boat is an hour away. I can get part numbers everything if needed this weekend.
Thank you.
Thank you.
