Furuno RPU-15 power out cable
Hi,
I've unsuccessfully searched for a part number for the 12v power OUT cable for my RPU-015. The connector is a 3 pin similar to the power in but smaller in size (3/8").
Cheers,
MDV
This port provides really low current so whatever you connect should be a max of .3 amp.
The 3 pin cable that can be used is part# 000-135-397
A salute to you sir!!!
Planning on powering a PG500 heading sensor @ .12amps.
Cheers,
MDV
