MFD12 AND SOUNDER ETR 6/10
L
leccese3
HI THERE EVERYBODY
JUST BOUGHT MFD12 NAVNET 3D CHARTPLOTER, CONNECTED THE ANTENNA GOT IT I HAVE GPS POSITION AND TIME, CONNECTED THE SOUNDER WITH MFD12 AND NO SIGNAL ??
MFD12 SOFTWARE VERSION IS: 1950055-02.11
MFD12 IS SET AS MASTER
WHAT I SHOULD TEST OR CHECK SO I CAN SEE SOUNDER DETECTED BY THE MFD12
WAITING YOUR KIND HELP
BEST REGARDS
If you run through the installation wizard you should see it.
Once done with the procedure there will be a sounder icon in the upper right corner and sounder will also be listed in the menu.
Thanks for the replay,
I run the wizard and nothing show up,
The sounder icon does not shows on the screeen.
Green light in the furuno etr-6/10 is on .
Do i have to activate an option on the mdf12 to turn on the ethernet ??
Waiting for your help ??
After power up the system, wait five minutes and check the sounder status light. What is it doing? Is it solid, flashing quickly, flashing slowly at a one second "On"/ one second "off" ?
Helllo there capitán
I went to the boat and turn everything on,
The etr6/10n starts with a flashing check and then stays solid.
The blue round 6 pin ethernet cable from the etr6/10n has a convertion cable to fit
The navnet 3d back etherneth switch.
As far as i hace read this old sounder model etr6/10n has a net name , net #, net submask, etc
This un order to be detected by displays and to transmit info ??
Waiting for your kind advice and comments
Regardss, Ettore
If the status light goes solid after 4 mins; then you have a communications error. Your cabling or hub connection should be checked. The sounder seems to be working okay at this point.
