New to me mfd8
Hi I have just purchased a second hand mfd8, when I start it up there is a message which says there is a problem with my system id, and it gives me a number. it says I only have 25 more starts before the charts become unavailable. when I go into the system it gives me a different system id number, there wasn't any sd cards with the mfd when I got it.
Can anyone please help me with this problem.
Les
It is a notice (not error) letting you know that it no longer sees the master unit in which any licensed charts were registered to. After the countdown gets to zero it will stop. This unit reads charts from an internal drive not the SD card. You use an SD card to load them into the internal drive and then remove. There is no surprise in not having a card in the slot. You might want to review the following links.
http://furunousa.com/ProductDocuments/N ... e%20V3.pdf
http://furunousa.com/ProductDocuments/N ... Charts.pdf
http://furunousa.com/ProductDocuments/M ... al%20H.pdf
Hi, if I go into the charts they are there but locked. How can I fix this problem , do I have to delete them all, start again and buy new charts for it?
Thanks,
Les.
You can use the second link I provided as a guide to update and download many free USA charts which are license free. The locked charts can remain, be deleted, or you can purchase a license for any that you wish to have. Keep in mind that the locked charts already on the unit are now most likely old versions so you should update anything you plan to purchase.
Ok many thanks, I didn't want to just buy new charts before checking all would be ok, once again thanks for your help
Les.
