chart loading on 2nd mfd 12
G
grumpyjk
:jump Have two mfd 12 and one mfd 8.Updated charts,raster and vector on my master no problem. On the second mfd 12 cannot load maps from the same sd card I used on the first one.I can save a file on the card.Neither slot top or bottom loads.
Should I blow out the buffers and try again???
Please instruct ??????????????? :huh
You can try a factory clear but it sounds more like a slight incompatibility with the SD card being used. Some brands seem to work better than others. I would try another brand card to see if you can get the charts to load. Your unit does show a chart catalog of existing charts correct? Because if the unit has a damaged chart catalog file you may not be able to load charts until the machine has been to the service center.
will try a new 16gb sd card.I saved to the sd card that would not take the charts from.I thought if I could save to it the sd card was reading
:jump
Thanks. Your solution worked.Loaded with a new 16gb sd card and it loaded :jump
