Bradscot311,
The sounder in the TZT2 is single channel, meaning it alternates between 50 and 200Khz. If it is still working on 50Khz that tells me that the T/R unit is still alive. Does the 50Khz side still look OK? The first thing I would advise is to go back and default all the sounder settings just to make sure something didn't turned on (or off) by accident. If after this the 50Khz looks OK but you still have nothing on the 200Khz side I would suspect the transducer.
