Depth data from DST-800MSF
flowmotion
I have the above transducer interfaced with the TzTouch2. It displays as an option for temperature and speed but not depth. The NEMA200 is setup up to transmit all 3 data types.
I also am running the DFF1 and DFF3D. The selections for desired depth source are the two latter units, the TZT2 and network. There is no 800MSF option.
Please advise what might cause temperature and speed to show up but not depth.
Thank you
If the DST is not providing depth, the unit will not use it. I would recommend using the NMEA 2000 monitor in Serviceman to look at the PGN data of the DST. I suspect you will find that depth is not present. This might be because the water depth is beyond where the DST can reach, or it is broken somehow.
