Tunacious Too
I have 2 TZT2 units, one at the lower helm that is the master. The other unit is in the tower.
I'm manually entering way points into the lower helm unit. This is a time consuming process that I hope I do not have to repeat on the tower unit.
1- How can I transfer the way point data from the master unit to the tower unit?
2- When I'm fishing off shore, I used the MOB button on the display face to save a point, like a a hookup, sonar mark etc. Is this still possible? I tested the MOB button at the dock and it made an alert with a red button. I also had a hard time erasing the MOP. Can someone explain the process of saving an instant way point off shore that I can rename and save in the way point list?
3- On my old Nav Net 1, when I saved a way point or MOB on the tower unit, the way point data did not save to the lower unit. Is this still the case with the TZT2?
Thank you.
Bob
Thank you.
Bob
