Connect TimeZero App to TZT2 WiFi
Status
Not open for further replies.
eheffa
I know... read the manual; but, I have without enlightenment.
I am trying to connect a WiFi only iPad running the TimeZero App to my TZT2 WiFi network in order to receive the relevant position, heading, SOG data etc.
I can connect to the Furuno WiFi without difficulty but I am not receiving the NMEA data. I believe that I need to connect via the TCP protocol. (The UDP protocol gives me a green light but no NMEA data.)
The TimeZero app Manual states:
“If the WI-FI multiplexer is using the TCP protocol, you need to enter the TCP port number and the IP address of the Wi-Fi multiplexer in the MaxSea TimeZero App.”
How do I find these TCP Port number & IP values for my Furuno WiFi Multiplexer?
Thank you for any suggestions you can offer.
- evan
PS. Using my laptop I am seeing the Furuno WiFi IP Address as: 192.168.43.190 but do not have a clue as to port number.
That isn't possible (to use the TZT/2 as of NMEA data source for Nobeltec TZ app) but you can discuss options with TZ/Nobeltec. The wifi on the TZT is only for the three established Furuno apps and connecting out to a hotspot for Active Captain and NavCenter weather.
Status
