Best Practice for MFD Chart Updates
Postby eheffa » Wed Feb 07, 2018 10:13 am
Hi again,
I hope the answer to this question is not too obvious.
I just activated my local Vector charts (Canada West - WVJNAM025MAP12.1) last weekend.
When I initially tried to activate the chart, I looked for the WVJNAM025MAP12.1file on the TZT2 catalog listings. (My TZT2 is not connected to the internet) I could not see the proper chart listed, so pulled the Micro SD card and tried to load the chart files onto the card. This failed with the message that there was not enough space on the 128 GB microSD. I put the card back into the back of the MFD and tried simply entering the activation code which worked. So it would seem that the chart was already loaded & I missed seeing it there. (I will blame my Y chromosome for that.)
In the meantime TZ / Mapmedia has updated this chart to version 13.1. I received an email notice of this and after my asking for it, received authorization to download and activate these new charts for no charge. (Thanks)
I have the new 13.1 version of the charts downloaded and have new activation codes.
(It would be prudent to back up the MFD microSD to a hard drive before I do anything further. I will do this.)
Now how to update these charts...? (I have read the instructions which won't work since I do not have enough room on the mSD card without some deletions.)
Options:
Option 1: Take the MFD MicroSD out and using a card reader on the PC, find the old 12.1 files, delete them and then load the extracted new 13.1 files to the same directory.
Option 2: Take the MFD MicroSD out and using a card reader on the PC delete a bunch of charts I am not likely to ever use (East Coast USA etc.) to make room for the new files then follow the instructions of loading the new 13.1 files onto the root directory of the MFD mSD card. Do i leave the old 12.1 files untouched?
Option 3: Load the new 13.1 files onto a thumbdrive, plug this into the USB port on the MFD and allow it to detect and load the new files (presumably onto the MFD microSD?)
Any suggestions appreciated.
-evan
eheffa
Re: Best Practice for MFD Chart Updates
Postby eheffa » Fri Feb 09, 2018 5:04 pm
I see good hints here:
viewtopic.php?f=28&t=3144
Still, the documentation on this question is not exactly easy to find.
Is it better to delete the files using the MFD or with the mSD out and in a computer? Does it matter?
-evan
eheffa
Postby Johnny Electron » Mon Feb 12, 2018 8:57 am
You can delete your old version of the map (SDVJNAM025MAP14) from your SD card using your MFD or your PC. I normally do it with my PC just prior to copying over the new version. (SDVJNAM025MAP15). Note that SDVJNAM025MAP15 is the main vector chart and part of the WVJNAM025MAP13.1 package. You can always see the complete package of files in a package but imputing the package number into the search at MapMedia.com.
User avatar
Moderator
Moderator
Postby eheffa » Tue Feb 13, 2018 11:26 am
Thank you very much.
Very helpful.
-evan
eheffa
Return to NavNet TZtouch2
Who is online
